Just looking at mounting my Intatrim seats into the Indy. I'm planning on bolting them directly to the floor through the steel straps welded
into the chassis. Plan is to use dome cap heads witha penny washers through the base of the seats, then penny whashers and nylocs under the floor.
What size to use - is M6 too small? or should I use M8?
Comments!
Nick
why not but the dome heads under the floor? less to get caught on something.
M8 with penny washers should do the trick
the threaded bosses on most seats are m8, so i figured that must be a good size.
m6 does seem a bit weedy.
tom
Nick,
Just one thing I realized when I came to bolt my seats directly to the floor in the Indy, are you sure the steel straps are in the correct place?!
Mine were not as I needed the seat right back against the bulkhead and the straps were in completely the wrong place. They may have changed the
positioning of the straps now but worth checking!
HTH,
Rich.
I got my seat runners from Midland Wheels good service and not expensive.
When you sit in the car this way you can adjust the seat to make yourself comfortable. I have long legs so I need the seat right back to get in and
out.
My wife has short legs so I can keep up the pretence that I will let her drive.
SVA manual says "at least" m8 of 8.8 strength
Shortie - straps are in the wrong place for the driver (that'll be me) but would probably be Ok for the passenger side.
I figured M8 would be about right, but that means going to the nut and bolt man again
Opinion seems very mixed on the quality of the seat runners available, but I can't really see any other practical option for the drivers seat
for the passenger side on mine, i used 1" rhs, drilled up for caphead bolts into the bottom of the seats, and down to put captive bolts through
the straps.
put the captive bolts in first, then bolt the rhs to the seat. i had runners the first time on the drivers seat, but will probably go with rhs this
time round.
give endless scope for seat position fore/aft.
tom
Originally posted by scoop
SVA manual says "at least" m8 of 8.8 strength![]()
does it not also have upper seatbelt mountings that are too low to satisfy sva, and bugger all castor?
squabs are a different animal to a one piece seat though. squabs by their very nature are well fitted. if you had scatter cushions, i'd think
they'd pull you up too.
tom
Tom - when you say "captive bolts do you mean something other than a normal hex head bolt?
