Hi, just got a carbon fibre dash from Luego. Could somebody advise me on the best way of cutting the clock holes as I'm worried it might splinter if I use a normal hole cutter. Thanks John
I cut mine with a hole saw, no problems, cut from face side. Bezel of instruments should cover the edge anyway
cover it in masking tape to mark it out & drill it. remove when finished!
Thanks, I'll probably give it a go then. I was only worried because it was quite expensive and didnt want to end up having to cover it. Thanks again John
Hi i've just been cutting my carbon dash this afternoon, covered it in masking tape then used some decent bi metal holesaws for the gauges and a
0-30mm step drill for all the other different sized holes, worked a treat.
Matt
