Paul / 907
Where my Relays are hidden:
The plate is 90deg bent ally with nutserts put in it.
Then all covered up with a bit of Stainless left over from the new Cooker head vent, again just held in with nutserts. Nothing exciting really.
Relay Plate behind Dash
Passenger Footwell
for security?
Hi Geoff.
I prefer the "Cluttered Look"
If you think this is bad you ought to see my work bench.
Paul G
p.s.
When are you getting a piccy reducing program?
I had to pan across just to find a smiley
Originally posted by alfasudsprint
for security?
Originally posted by 907
Hi Geoff.
I prefer the "Cluttered Look"![]()
If you think this is bad you ought to see my work bench.![]()
Paul G
p.s.
I had to pan across just to find a smiley![]()
Is that a heater matrix in the bulkhead..?
I was considering doing something similar and using individually switched PC fans to power the vents etc
They are good for up to 50cfm, cheap and quiet !
Peter
