Hi There
Does anyone know if the Mountney M Range steering wheel is SVA compliant. And if so do you know where I can get official information to prove so
before I go for the test.
Adrian
cant remember the M range but if its got metal in the middle ie like a three spoke then NO
you need the padding
My SVA examiner failed my car because the steering wheel wasn't compatible with the rest of the column - presuming he meant the column and wheel
are a previously type approved assembly.
Therefore, I'd leave the Sierra wheel on, then change after test. I changed mine while examiner was inside writing out my MAC
Simon
You can get SVA pads for Mountney wheels. Europa sell them iirc. Alternatively try and find a Miata (import MX5) which have a pad fitted as standard.
