Do the seatbelt mount point nuts need to be welded to the chassis or will nylock's be OK for the SVA ?
I believe they need to be welded,
but I don't have access to an SVA manual to proove it.
Mal
I think they need to be welded so they are effectivly part of the chassis
I don't think they necessarily have to be welded but you have to be able to undo them from the driver's seat ( or something like that) which effectively means you can't use loose nuts under the floor etc
Yes captive nuts are require --- use proper ones don't just weld an ordinary nut on.
You can use a 'bolt and nut' where you can get access to the nut. Captive nuts are NOT mandatory.
From the SVA manual....
"...The bolt may be secured into an alternative fixing, eg a locknut of suitable strength, where access is provided to the 'rear' of
the mounting to enable separation/re-attachmentof the belt"
From Section 5 of the manual.
Bolts (and nuts) have to be 7/16 or 11mm high tensile. and clearly marked as such.
Syd.
Hi I was thinking of making the nuts up out of some hex bar and welding this to the chasis with spreader plates. while the bolts have to be of a specific grade of steel is there any regulations on the nut
