Hi all
I've made a buck to make moulds off, to get a good finish on the buck i painted it with high build primer, sanded back and gave it a top coat of
gloss black car paint
tried making my first mould yesterday, went to seperate tonight and the resin seems to have melted the paint? had a right job seperating them, any
ideas what i've done wrong?
Adrian
i'm not sure you should paint it. i think there's some kind of release wax you put in there instead
have read you do have to paint it, but give it a lot of waxing before moulding. gel coat must also be thoroughly applied. sounds like maybe you
didn't wax it enough?
funny i'm JUST about to start moulding myself, so it'd be interesting to find out what went wrong with yours.
Edit: oh i have just read you made the mould yeaterday and separated it today?. aren't you supposed to wait until fully cured, which is like a
week? one day seems too short to me no matter how small the piece u made..
[Edited on 5/12/07 by robertst]
Did you use celulose paint?
If so that is a no go with normal resin.
You have to use 2 pack.
I have seen celulose used with epoxy resin though. It's more inert apparently.
Did you use a release ageng before you applied the gel coat.
That was quick
Used a pva release agent, athough it did dry a little steaky, paint was halford own brand, could it be celly?
Adrian
itll be cellulose if its melted the paint , sometimes aerosol 2 pack can be bought , that seems to melt aswel , ask me how i know .
Yep, wrong paint.
I have found that in general a two part paint or varnish will be fine with fiberglass resin.
Spray can stuff just melts. I did it once too and it looked very,, scrotumy.
Was gutted. You only do that once though so the hard bit is by at least.
I've been making a mould for a dash board at work. the mould is built using MDF/, radiused (19+mm) with body filler (which is generally polyester
based). Onto this i built up a good layer of exactly the same paint as you have mentioned - Halfrauds Hi-build primer and a regular can of grey
primer.
The hi-build is used to fill any surface pores. This is then sanded back (wet n dry), cleaned with soapy water and a layer of normal grey primer
applied. It is important to test the paint with your resin first. As said, epoxy tends to be less agressive, whereas the styrene in polyester will
cause the paint to dissolve.
I applied two good coats of wax, then an additional 5 coats of as PTFE release spray. I had no issue with the resin dissolving the paint. I will post
some pics soon as I may have a few spare dash blanks!
the styrene solvent in polyester resin disolves all sorts of other things, including paint and polystyrene foam. Wax coats will not stop it.
If you can separate your buck out of the mould, you will have to refinish it with something other than paint. Sorry.
Thanks for the replies
got mould and buck apart, bucks ok, but need coating in something to cover the filler etc.
Any recomendations on a more durable paint / varnish?
Adrian
was going to have ago myself soon.
Would enamel be any good ?
nope .
polyurethane varnish , 2 pack paint or polyester reface can be used .
if its a rough mold , pva , spray wax coating etc .
Originally posted by ady8077
That was quick![]()
Adrian
I've said it here a dozen or more times already, but I'll say it again....
PVA has no place in a professional grp workshop, so don't use the stuff.
Plenty of wax is the only answer, and gives a smooth finish, which the pva will not.
Put the wax on--allow to dry--buff with machine preferably--allow to harden(anything up to 2hrs or more in this weather)---apply more wax---- and on
and on.
6-8 coats of wax should work. It is imperative that the wax be allowed to harden between coats, otherwise the new coat just wipes the previous off. As
Volvofella says, 'ask me how I know.'
Plug surface needs to be 2pack at a minimum. I know other cheaper paints can work, but 2 pack and wax never fails. Well, for me anyway.
Syd.
Put the wax on--allow to dry--buff with machine preferably--allow to harden(anything up to 2hrs or more in this weather)---apply more wax---- and on and on.
6-8 coats of wax should work. It is imperative that the wax be allowed to harden between coats, otherwise the new coat just wipes the previous off. As Volvofella says, 'ask me how I know.'
Syd.
Syd how can you say PVA has no place in a GRP shop? Yacht builders use it all the time for textured/slip resistant surfaces on mouldings, as wax doesn't go on well on highly textured surfaces. Admittedly, this is not, and I agree not the best choice here, but it does have its uses...
surfacing primer
Fred W B
Originally posted by twybrow
Syd how can you say PVA has no place in a GRP shop? Yacht builders use it all the time for textured/slip resistant surfaces on mouldings, ...
We make major structural parts for aeroplanes, and we have PVA in our shop...!
It doesn't tend to get used on the carbon/epoxy work we do (certainly not in production) , but it has its uses in other areas of composite
manufacture.
One could argue that your use and campaign for use of wax is somewhat primative - why not only promote semi-permanent release systems?! It's
becuase different parts require different slip properties and surface finishes. there is a use for PVA, but obvioulsy not for the work you are doing.
Wax, primitive?? That's a bit rich coming from someone promoting pva!!
PVA is horrible stuff.
Geez,in a hurry, I've put shellac directly onto mdf patterns, then wax and moulded straight onto that. You can stick that pva where the sun
don't shine!
I know about and use the modern(? It's been around, in various forms for more than 30years) stuff, but who on here is going to spend £120+/us
gallon for a small project? When he can go down the road and get a tin of original Simoniz hard wax for a few pounds and get the job done just as
well?
I'll say yet again, PVA has no place in grp work which is being done properly! Even half properly.
Syd.
[Edited on 6/12/07 by Syd Bridge]
Hi all
Thanks for the advice, any recomendations on the best wax to use?
Also i have another part to make, an airbox, forwhich i have used plaster. I have sanded it to shape and was going to paint it, as 2k paint is abit
dangerious for home use would i be best to varnish it? or will wax be ok on bare plaster?
Thanks Adrian
Carnauba wax is the original and you can get it in aerosol. I used block furniture wax polish for the little bit I did and it worked alright.
