I'm currently in planning phase of my car, and am new to the forum. I'm going a bit 'radical' with the car and wouldn't like
to have too much of the driver sticking out of it. I've come up with this position (I hope there will be no need for detachable 12" steering
wheel)- which surprisingly doesn't feel uncomfortable sittong on the floor with back supported by inclined wooden plank... My intention is to use
a GRP bucket seat and 5 or 6 point harness to hold the driver in place (everything above shoulders will be sticking out of the car), which would
hopefully help things a bit.
Any thoughts and comments are welcome. TIA
P.S. this is indeed a mannequin of rougly my build and size (I've set it to be my height and weight)
[Edited on 25/1/08 by Wolf HR]
I cant help you, but the answers should be interesting...
What program have you used for the manequin?
I used trial version of ManneQuinPRO. At the bottom of the page is the link to download 30-day free trial version. HTH
http://www.nexgenergo.com/ergonomics/mqpro.html
Looks good, just make sure that you have enough ankle/ leg movement to operate the pedals confortably, particularly holding the clutch down. Another consideration is pulling on the handbrake, especially if is to be on top of the tunnel.
You need to make sure that your knees are bent and then supported, otherwise your legs will quickly get tired.
Thanks guys, you're very helpful. Handbrake- now there's something I'd never have thought about (but I'll probably stick it on the
passenger side of the tunnel). There will be footrests next to pedals.
In case anybody's wondering, poor driver will hopefully be squeezed into something like this:
What might prove to be the problem is that only things adjustable in this setup would be pedal box location and steering wheel.
I don't like the idea of being covered in wire mesh.
You will need to support you legs further forward(near to u/side of knee, as in a single seater, most racing cars have fire extinguisher under there
which helps.
I am looking at a similar seating position but cannot find f/glass seats with that much rake at the moment
I think your knees need to be bent a bit more and the thighs well supported and also the arms need to be bent a bit more - it's best if you can
comfortably, without stretching or moving your shoulders forward, rest your wrists on top of the steering wheel.
A semi-reclining position puts quite a lot of pressure on the base of the spine and is tiring on even a short drive if your knees and thighs arent
well supported.
Since we're discussing the subject, I just remembered I have this on my HDD- clipped from a factory drawing of Porsche 917... Just in case
somebody finds it useful in any way.
I have a shoulder problem and had to sit my seat up more upright and bring the wheel nearer as my right hand was going numb when I was sitting like your drawing. You'll probably find it better to modify your seating after you drive the car.
Originally posted by hampshe
You will need to support you legs further forward(near to u/side of knee, as in a single seater, most racing cars have fire extinguisher under there which helps.
I have the Tillett B3.5 in my Phoenix. They would give you a similair rake to the what your after. I drove to the Ring and back with them without a problem (longest stint was 250 miles).
I would be highly dubious about the seating position. In an accident, you will be propelled forwards and down - putting the crotch straps of the
harnesses under a lot of strain - probably doing irreperable damage to your wedding tackle!!
I think you need to be more upright, possibly lowering the seat into a recess in the floorpan.
Even with your body reclining, your head will be more vertical, especially if you are wearing a restraint collar.
wolf,
from what I found out about my seating position for my single seater, after I built the wooden mockup, is that your position has the wheel too far
away, and the legs are too flat..
In fact I had a seat in the red bull F1 car, and they have the steering much closer to waht you want to do, and the legs are more bent..
in fact, here is my approximate seating position, the hands will be a bit higher up as the steering wheel shaft is lined up with the top tube..
it is not the eyes that bother me, but the square shoulders cut trough most harneses..
Bump
Here are some Bosch templates:
http://www.ergonomiesite.be/antropometrie/sjablonen/BOSCH-groteman1m87.pdf
http://www.ergonomiesite.be/antropometrie/sjablonen/BOSCH-grotevrouw1m76.pdf
http://www.ergonomiesite.be/antropometrie/sjablonen/BOSCH-kleineman1m66.pdf
Should be very usefull
http://www.ergonomiesite.be/antropometrie/sjablonen/BOSCH-kleinevrouw1m54.pdf
