I want to purchase some new harnesses and am a little confused with the TRS offering.
It says Clubman style and Clubman Westfield style but when you order off the website there's just the *Clubman* to select.
Whats the difference and will a normal set fit my MNR?
[Edited on 17/2/08 by coozer]
I think mine was a Westfield, or maybe even Caterham short version. If I were you, I'd ring Colin Denyer Motorsport on 01483 275406.
HTH
TC
Hi
Ive got TRS Harness Clubmans version, you just need to specify 3or 4 point option, and bolt on or clip on.
I think the Clubmans version is the basic verison like i have which by default is connects with bolts. Maybe the westfield version uses the clip on
with eye bolts.
