where to buy the black plastic sheet with a grain effect on one side ? any help appreciated...
http://www.woolies-trim.co.uk/c-146-millboard.aspx
Not plastic but will this do?
i saw this a Woolies but i need /want the plastic stuff as it has to be water proof ,thanks anyway...
Signmakers use a plastic board called Foamex which comes in 3mm, 6mm & 10mm thicknesses - I have used it in the past to good effect.
Googled Raz's Foamex and found These Peolple.
Amari Plastics.
Albion Plastics.
Ask for Black Embossed Polypropylene. (it has a leather grain look, as i'm using some for a solid boot cover)
I work for the latter one in Bristol.
Amari are all over the country
