is there any other indicator storks i can use then the sierra. iam after some with a nice fitting and some stainless storks or aluminuim. because i
think the sierra storks are a bit naff.
adam
These may work, on ebay, not mine, never seen them. May be worth considering though.
http://cgi.ebay.co.uk/INDICATOR-SWITCH-COLUMN-MOUNTED_W0QQitemZ380019067065QQihZ025QQcategoryZ100921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
There's a way of modifying the Sierra stalks - if you can wait until tomorrow I'll show you a picture of what I did.
basically, if you saw the stalk off in the right place you will find a convenient hole. You can glue a length of 3mm steel rod in the hole, and then
glue a nice flashy stalk onto that.
I made my replacement stalk, but I'm sure someone was selling nice ones on ebay.
