Airbox that fits across a bank of 4 bike carbs as well as webers..will need flexi pipe to allow airfilter to be mounted where it can suck cold
air...down in the nosecone somewhere I guess
£65.00 as fiddly blighters to make
Mark
do you have a piccy??????????????
Couldn't find the new picture so nicked this from my archive.
Mark
Umm bit mucky but you get the gist ...
Mark
What size is the inlet Mark?
cheers for that
thats yet another reason to spend money
doh
Inlet will take 2" flexi pipe...but will check in the morning and make sure I didn't dream that up!!!
Mark
Any chance we could have some overall sizes,is the base plate included?
I'm sure I've seen something like that in hospitals but they have another propose there
Looks great. Take it this would fit a '03 R1 MK Indy no problems? So do you just need to run a cold air feed 2 inch and attach a cone filter in the nose cone?
Hi just remeber if fitting one of those type of air boxes you will need to be re jetting your carb setup too.
cheers Matt
Better they suck cold air than stuffy old hot air under that 'glass or ali bonnet.
Re jetting will most certainly be needed and would say a rolling road session would be the best bet to get the most out of what you have.
Cone or sock type doodah down in the nose where it can suck cooler fresher air.
Mark
Are you able to offer 1 of these with a 3" inlet?
Do you have any dimensions and better pictures?
