Morning all
Anyone here any idea what M size bolt should be used to attached the cobra roadster seat to the runner and how long should they be?
Just thought I'd check before wading in with a knife to the bottom of my seats.
Pretty sure they are 8mm. Length only needs to be about an inch long as the runner is not that thick.
I think it's 8mm as well. My bolts were 25mm but go through the floor with a plate to spread the load.
yes deffinatly M8
How well do the Roadster 7 seats fit into the Indy. I want to use these seats, but when I measure I only have 425mm from the transmission tunnel to the outside, and the seat spec states 440 (I think)
