are the areas round the steering wheel mentioned in the sva manual allowed to be long with sharp (ish) edges?
i just want to be 100% sure so i dont fail
127mm from the edge of the wheel rings a bell.
cheers, i thought it was that... ive got an omp wheel...cant fit in otherwise!
Hope this helps, got it off the forum a while ago.
Hi,
Can someone confirm that I'm reading the rules correctly; areas A,B and C are all exempt? Also how exempt are they? ie how "sharp"
can something in the exempt area be? is there a limit or anything goes?
