2.0 turbo cosworth engine
The head is currently removed and would advise inspect/refresh
205 block
4x4 head with 2wd thermostat pipe outlet
2wd rocker cover
Full inlet manifold with blue injectors
Ex manifold
T3 turbo fresh rebuilt and modified to T34 with uprated comp wheel machined housing and 360 thrust bearing
Flywheel
Gasket set
Wiring loom
Ecu
D valve new
Rs500 alterator drop bracket
Motorcraft new parts = oil f , plugs , dizzy cap, fuel filter
£2000.00
2wd cossie gearbox
£450.00
Cheers Joe 07855369369
