acewell speedos
davrus - 1/11/06 at 07:55 PM
Hi ya , got aan acewell speedo on its way , can any one tell me where the best place to put the speedo sensor and any pics would be appreciated
Many thanks
Davrus
JackNco - 1/11/06 at 08:17 PM
Just out of interest which one did u go for? every one seems to use the 31XX but ive got my eye on th 2853
stevec - 1/11/06 at 08:31 PM
I mounted mine on the O/S rear inner driveshaft joint and the cable part on the diff using a bracket off the Little torx bolt that adjusts the pinion bearing.
Steve.
Cobblers just seen your pics,(live axle) sorry, Looks a propshaft fitting then.
[Edited on 1/11/06 by stevec]
Howlor - 1/11/06 at 09:43 PM
Propshaft towards the front. Nice stable reading and cock on for the SVA.
nib1980 - 2/11/06 at 07:50 AM
Hi, Can I be cheeky and ask if you have any pictures, as i was condsidering this.
many thanks in advance
Paul G - 2/11/06 at 10:01 AM
apologies for the blurred pic but I put mine here with the magnet sikaflexed in one of the holes
http://moog-designs.co.uk/MK_Indy/pages/DSC00046.htm
andy_mullin - 2/11/06 at 01:30 PM
I dont have anything at the moment.
I have a 1000 faser, and was looking for some clocks.
Is the Acewell any good with a BEC, I will only use the car for trackdays so I need a rev counter, oil pressure, water temp and a neutral light.
