Hi all, anyone know what the stock fuel pressure is on the 98-9 ZX9 pump?
Its a neat size to replace my dead fireblade pump, and im hoping it goes to the 1.5psi that the blade pump goes too.
many thanks.
It will most likely be the same Mitsubishi pump as your Fireblade. You can get spares for fuel pump from Wemoto.
Ah excellent ill have a search. thanks
aslong as theyr both carb pumps they will be near enough the same.
Mr Haynes says that the fuel cut off pressure for the pump is 1.6 to 2.3 psi.
Right i see, thanks guys, ill buy the pump as its only cheap on ebay, its from a carbed engine so worse comes to worse ive only lost a few quid.
