Zetec type 9 clutch release bearing
kylerichmond - 26/7/10 at 05:25 PM
I fitted a 2.0l zetec silvertop to a type 9 gearbox with a 1.8 retroford flywheel re-drilled to take the standard pinto clutch, my problem is what clutch release bearing should be fitted?, there is lots of confusion out there, i have a feeling that the one already fitted is a cct132, however many people recommed the cct133, also the 3rd option is ct303, how do i tell which one it is?
The bearing i removed is an INA number F-89958, Ford number 8388-7548-aa, nobody seems to be able to match of cross reference it
coozer - 26/7/10 at 05:27 PM
CT133 Capri one is what you need.
If all else fails try GMSCAPRISPARES in Coxhoe.
RichardK - 26/7/10 at 05:54 PM
^^ What he says
Rich
big-vee-twin - 26/7/10 at 06:18 PM
I have a new one on sale on Ebay, if you're interested here's the link linky
coozer - 26/7/10 at 06:22 PM
Butee D'Embrayage... MINT
lotusmadandy - 26/7/10 at 06:41 PM
Kupplungsausrucklager is far funnier
austin man - 26/7/10 at 09:20 PM
shouldn't it ne the standard sierra bearing, the capri item is recommended when using the zetec clutch with a type 9 box.the sieera / pinto pressure plate springs sit significantly higher than the zetec plate
kylerichmond - 27/7/10 at 08:19 AM
From the pictures, it looks to me that ive been using a standard type 9 bearing and its been working fine, it worked well although the pedal was a little high
