j30fos
| posted on 29/1/04 at 09:42 AM |
Rubbers for the indy pedals
What do they come off, and where did you guys get them from.
John
| posted on 29/1/04 at 10:29 AM |
Jon,
I've used some alloy pedal covers from Demon Tweeks. The bolt to the MK pedals with a slight mod and have a bigger pedal area, with non-slip
faces.
HTH
Nick
theconrodkid
| posted on 29/1/04 at 11:23 AM |
ive got a set you can have for £10 including post,let me know and ill send you a pic
who cares who wins
pass the pork pies
vintagebuilder
| posted on 29/1/04 at 10:23 PM |
Indy Pedal Rubbers
John,
I saw a pic on the MK9R web site showing a rubber pedal cover. I e-mailed Austen and he told me he got the rubbers from a kit car show but thought
they were available by mail order from kit car sources. To date I have'nt been able to locate any. Hope this helps.
| posted on 30/1/04 at 09:02 AM |
someone told me to use sticky backed rubber strip.
wicket
| posted on 30/1/04 at 12:27 PM |
Grant at Luego suggests using fairly coarse grit emery cloth fixed with contact adhesive. An alternative is grip tape used on skate boards or tread
areas on aircraft wings.
Markp
| posted on 30/1/04 at 07:27 PM |
I'm not sure about yours, but, i used the stuart taylor floor mounted pedal box.
I went to halfords and asked about pedal rubbers and they got a selection out. I used (i belive) the transit ones and they fitted perfectly and only
cost about £5 for the accelorater pedal I used the non-slip paper that they use to put on skate boards. Very good stuff!
Hope this helps
Mark
DEAN C.
| posted on 6/2/04 at 10:26 PM |
I've used MGB rubbers,look smart and are easy enough to get hold of at shows or autojumbles and fit perfect.
Transit are shaped too much and dont fit perfect.
Once I've finished a project why do I start another?
Mk-Ninja
| posted on 6/2/04 at 10:41 PM |
Conrod did you sell the one you had or are they still available.
Gordon
I'm sure I've got one, just don't know where I've put it
theconrodkid
| posted on 7/2/04 at 07:52 AM |
ninja you have mail
who cares who wins
pass the pork pies
Mk-Ninja
| posted on 7/2/04 at 08:57 AM |
You have reply
skippad
posted on 11/2/04 at 10:05 PM |
Vauxhall Corsa pedal rubbers are a nice tight fit- Scrapyard 0££'s
bonerp
| posted on 17/2/04 at 08:08 AM |
I Used skateboard grip tape. Cost £4.50 and you get so much at least another 10 builders could do theirs in it too!
Sorry, mines spoken for before you ask now!
Paul
