ahunt
| posted on 28/6/09 at 02:20 PM |
Bolting seats to chassi rails
Hello,
Sorry if this has been cover before, but.... If i were to make brackets rather than welding bars to the chassi rails. would it be acceptable to drill
and tap into the rails and have 4 bolts per bracket holding it on. just at the point of working with what ive got before i can buy seats
Adam
[Edited on 28/6/09 by ahunt]
Ben_Copeland
| posted on 28/6/09 at 03:00 PM |
Yes, mine are bolted to the steel floor with spreader plates. That was fine.
Brackets should be fine. As long as they are man enough and you use suitable bolts.
Bolts and Nuts are better than taping
[Edited on 28/6/09 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
eznfrank
| posted on 28/6/09 at 04:30 PM |
I may have misunderstood what you've said here but are you suggesting that the seats will be held in place with a bolt through a tapped thread??
ie. No nut??
ahunt
| posted on 28/6/09 at 06:42 PM |
This maybe a little clearer. i mean drilling and tapping the actual rails so as the picture im bolting a frame to the chassi but tapping the rails out
and using lock head nuts to secure the frame. And then bolting my seats to these frames...
adithorp
| posted on 28/6/09 at 06:53 PM |
The tube wall will not be thick enough to take tapping.
adrian
http://jpsc.org.uk/forum/
stevegough
| posted on 28/6/09 at 07:10 PM |
Rivnuts?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Triton
| posted on 28/6/09 at 08:27 PM |
Depends on the seats and how they are mounted but 16swg tube won't take a thread unless weld a threaded boss on or use rivnuts but then most
seats will require a nut to secure them anyway......Oh and I know a nut who makes them
www.tritonraceseats.com
www.hairyhedgehog.com
Chippy
| posted on 28/6/09 at 10:32 PM |
I think that if you fix something through a tube, then SVA/IVA require that there is a welded in spacer to bridge the hollow section. Don't know
if that would apply to seat mountings, but I bet that it will. Cheers Ray
Triton
| posted on 28/6/09 at 10:39 PM |
Yes indeedly they will and should be done for your own safety and piece of mind.
ahunt
| posted on 29/6/09 at 11:05 AM |
ok ill just weld some flat to the rails itll be easyer, cheers guys
