greed1
| posted on 27/2/10 at 12:03 PM |
dash help
how do you trim down the dash to fit it to the scuttle
thanks graham
Drive it stright sideways
zetec
| posted on 27/2/10 at 12:13 PM |
Just hold your dash blank against it, or a piece of card/wood to make a pattern, and run a pencil or scriber aroun#d the scuttle outside edge.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
greed1
| posted on 27/2/10 at 12:42 PM |
thanks but how do you cut it
zetec
| posted on 27/2/10 at 12:54 PM |
What is it made from?
greed1
| posted on 27/2/10 at 01:59 PM |
plastic (carbon effect)
its all marked out now
this one
[Edited on 27/2/10 by greed1]
Miks15
| posted on 27/2/10 at 03:32 PM |
with plastic, id personally go with a very sharp stanley knife, just take you time, make sure the first score line is perfect, and each time you do it
after it will follow that, just nice and slow til it breaks through then clean up with a small file
:{THC}:YosamiteSam
| posted on 6/3/10 at 04:30 PM |
if you can get hold of one or borrow use - band saw works great on plasticy type stuff.. test on scrap first to see if fine or rough cut blade
hicost blade
| posted on 6/3/10 at 05:06 PM |
2nd a sharp knife, but be veeeery careful not to slip and do it on the reverse side, I would also make it slightly over sized and use fine sand paper
to finish
greed1
| posted on 7/3/10 at 08:27 AM |
thanks for the help i did go with the sharp knife and made i over size now for the sanding
oh and i recommend that no one drops that sharp knife on there toe
