givemethebighammer
| posted on 8/6/04 at 05:18 PM |
Dash padding
Just making my SVA dash (the nice carbon one will have to wait until after). I intend to glue some camping roll mat to the front of a piece of MDF
then cover it in vinyl material.
Questions are;
1. Do you cut the padding right up to the edge of the dash or leave a gap (I read somewhere you should leave a gap of about 5mm between the edge of
the dash and the foam ?)
2. With 6mm MDF and 6mm of padding will I still need to add material to get the correct radius on the bottom edge ?
thanks
[Edited on 8/6/04 by givemethebighammer]
| posted on 8/6/04 at 06:17 PM |
If you pad it over the edge of the dash then pull the vinly tight while you staple it at the rear it will give you a soft curve that should be o.k. as
long as the padding is still compressable.
givemethebighammer
| posted on 8/6/04 at 10:36 PM |
thanks, this dash doesn't have look brilliant, just OK. I intend to change it for something more "appropriate" post SVA
