davrus
| posted on 15/10/10 at 06:41 AM |
Speedo cable modification
My cable is about 2 feet too long, Is it possible to cut the outer casing down then trim the inner cable?
Is the inner cable square all the way down it or only on the ends.
Many thanks
| posted on 15/10/10 at 07:18 AM |
ends only.
can you not route it in a way to take up the slack?
failing that, check out speedy cables - will make you one to your spec.
blakep82
| posted on 15/10/10 at 07:23 AM |
2ft, over to the passenger side under the dash and back again?
________________________
splitrivet
| posted on 15/10/10 at 11:25 AM |
Cut mine down used a wire straight crimp to join the inner, then sleeved the outer cut ends with thin wall steel tube and crimped this over the outer,
works OK.
Bob
paulf
| posted on 15/10/10 at 01:33 PM |
I cut down a sierra one and rejoined the outer just by pushing each half into a bit of rubber hose about 6 inches long and then secured with jubilee
clips.It has been ok for the last 6 years.
Paul
paulf
| posted on 15/10/10 at 01:35 PM |
Paul
paulf
| posted on 15/10/10 at 01:37 PM |
Just remembered i used an escort cable for the inner as it was shorter than the Sierra one so just cut the outer to suit, the escort cable had a screw
fitting for the gearbox so couldn't use that.
Paul
Paul
davrus
| posted on 15/10/10 at 06:53 PM |
Thanks for replys.
I think i will run it around under the dash and leave it the lenth it is.
Thanks again
