carpmart
| posted on 11/1/11 at 03:39 PM |
Seatbelt mounting eye bolt question
Is there such a thing as a 90 degree bent seatbelt eye bolt?
Due to space issues, I need the thread to be at right angles to the eye.
Thanks in advance
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
matt_claydon
| posted on 11/1/11 at 04:07 PM |
I don't think so, and you wouldn't want to use anything that wasn't designed for the purpose.
Can you not just use bolted fixings for the belts instead of clip-on?
carpmart
| posted on 11/1/11 at 04:15 PM |
Yes I could but I have a set of clip on belts. Are you suggesting to bolt with a big washer through the clip on fitting?
'94 MX5 MK1, 1.8
speedyxjs
| posted on 11/1/11 at 04:29 PM |
I have a similar problem to you but only with the passenger. A bit of a lack of leg room for them
loggyboy
| posted on 11/1/11 at 04:33 PM |
For 'harnesses', but not seabelts:
http://www.liftingsafety.co.uk/product/swivel-eye-bolt-2297.html
matt_claydon
| posted on 11/1/11 at 04:44 PM |
Sorry, didn't realise you already had the belts. That could work, but the harness end plate must be free to swivel. A bolt with washer would
look a bit of a bodge, but a flange-headed bolt with a suitable length, maybe 10-15 mm, plain (unthreaded) section under the head might work. Depends
on the design of the harness clips I guess.
daniel mason
| posted on 11/1/11 at 05:00 PM |
top hat spacer for belt to swivel on,bolted from above
big_wasa
| posted on 11/1/11 at 06:04 PM |
A clip on belt will not go over a 7/16" bolt.
