Waitey
| posted on 21/2/12 at 04:52 PM |
Tidying up the interior
Gents,
I'd like to tidy up the interior a bit (Mainly to hide the frame work as the previous owner slipped with the mastic!).
Do any of you know where MK get the plastic they use from the trans tunnel panels from?
Thanks.
305bhp All Steel Duratec Westie
loggyboy
| posted on 21/2/12 at 05:18 PM |
Cant you just try some thinners/solvent based substance to loosen the excess mastic and trim the large bits it off? Just becareful to try it against
some inconspicous are of FG first.
wylliezx9r
| posted on 21/2/12 at 05:22 PM |
Sorry to hi jack the thread, but where do you get the angle trim that is running up the transmission tunnel.
I spent a lot of money on booze, birds and fast cars. The rest I just squandered.
George Best
Bluemoon
| posted on 21/2/12 at 07:03 PM |
It will be the MK supplied It's J section "hocky stick" quite common stuff used in horse boxes ect.
[Edited on 21/2/12 by Bluemoon]
Davegtst
| posted on 21/2/12 at 07:19 PM |
I used 1mm aluminium powdercoated black which imo looks far better than the plastic i was supplied. I also put polystyrene between the panels which
makes it feel alot more solid.
It's called cope moulding no 11 and is exactly the same as MK
supply.Yoiu can get the hockey stick trim from
here
[Edited on 21/2/12 by Davegtst]
| posted on 21/2/12 at 08:40 PM |
That's a pretty tidy interior already IMHO.
Rather than add excess weight, why not paint the inside of the side panels black.
MattStorey
| posted on 9/3/12 at 02:21 PM |
Hi, looking to replace my dash and having seen the OP's can you advise on who made the dash, what it is made out of? (looks all shiny -
plastic?)
Cheers.
