sdh2903
| posted on 16/5/12 at 06:49 PM |
Clip in harnesses
Now as far as I understand Clip in harnesses are ok for Iva, I plan on wirelocking the clips when fitted to prevent them coming off to satisfy mr IVA
man.
However Do I need to cover the whole clip assy with a triangle cover from a scrappies? or will edge trim around the edges suffice?
daniel mason
| posted on 16/5/12 at 07:07 PM |
are you planning on using eye bolts to fasten the upper harness mounts? dont think they will pass unless they have strength markings on them. or at
least thats what i was told at my iva a few weeks ago! luckily i swapped mine at mnr for some that just bolt on with a spacer!
sdh2903
| posted on 16/5/12 at 07:20 PM |
Interesting point, The eye bolts I was looking at were described as FIA approved which I thought would be enough now that FIA approved harnesses are
satisfactory. Would a datasheet as evidence satisfy IVA then?
johnwilders
| posted on 16/5/12 at 09:32 PM |
I haven’t had my test yet but my understanding is if they are 88 marked they are OK. You do have to sort out the edges etc though.
