Irony
| posted on 29/10/14 at 12:41 PM |
3mm radius on Aluminium Sheet
I have spent a couple of days trimming and making the parts for my centre console on my cars interior. I have made and sewn both the Handbrake gaiter
and the gear lever gaiter myself as well as the metal trim to go round them. Looks pretty good so far.
I have made some metal trim (to go around the gaiters) from 3mm Ali sheet and polished them up but I don't think they will pass the IVA. Does
anyone have any ideas how I can put a radius on the parts? I was going to just get the angle grinder out and bevel the edges with a sanding disc but
there might be a better way?
[Edited on 29/10/14 by Irony]
bi22le
| posted on 29/10/14 at 12:53 PM |
Can you get a metal cutting router blade and router the edge?
Not sure if they even exist.
If not, when I made my trumpets I hand ground them with a dremmel and then filed and polished.
A good hand file would put a 3mm rad on ali with little effort.
Please read my ring story:
Andy S
| posted on 29/10/14 at 12:54 PM |
Only needs to be blunted if it does not project from the surface so just take the edge off with a block and 240 grit
britishtrident
| posted on 29/10/14 at 12:58 PM |
You need to use a file, use the draw filing method and dust the file with talc.
[/I]
Irony
| posted on 29/10/14 at 01:02 PM |
I am not sure metal routing bits exist. I have never seen one. The parts stick out 3.5mm from the surface so they will need a good radius on them.
dave_424
| posted on 29/10/14 at 01:14 PM |
Any of the carbide router bits will cut aluminium without any issue
Smoking Frog
| posted on 29/10/14 at 02:16 PM |
As suggested a tungsten carbide router cutter will work (I did the tunnel trim using one) using several passes. However on such a small work piece
I'd use a file.
killerferret666
| posted on 29/10/14 at 02:52 PM |
depends how it attaches etc...
but I just got some rubber door trim and put it round my gaitor fitting as I had the same issue. after the IVA it fell off
Building DDR GT4
Miami Gt4 Blog - Click Here
big_wasa
| posted on 29/10/14 at 02:57 PM |
I just glued some u trim around it as well. Keep the glue to a minimum
Irony
| posted on 29/10/14 at 03:43 PM |
I actually prefer the sharper edged look of it now and I have some suitable U-trim. This could work methinks. Cheers
| posted on 29/10/14 at 07:59 PM |
I used a belt sanding table to radius the edge of my handbrake surround , the gear lever surround was done in a lathe
omega 24 v6
| posted on 30/10/14 at 12:20 AM |
Get a big grommet. Turn it ouside in and fit it to the part. After IVA throw it away and put the shiny bit back on how you like.
The Black Flash
| posted on 5/11/14 at 09:39 PM |
File, then emery paper from 240 to 1200. You'll have it done in an hour, it's how I did mine. Ally's pretty easy to shape by
hand.
