ChrisJ15
| posted on 18/8/18 at 01:03 PM |
Interior paneling and plastic mounting
The sills in my J15 are large so I have opening tops to them for storage. The problem is without any dividers things clatter about (especially with
lively driving! ).
What I'd like to do is use a plastic profile a bit like this...
__¦¦__
So the base can be velcroed to the inside of the sill and some palstic materical can be inserted between the two vertical sections and maybe rivetted
through.
Trouble is I can find that profile of plastic or any suitable plastic sheet. I've seen some plastic sheet that is embossed to look like vinyl
but cant find a supplier.
Any ideas?
Andybarbet
| posted on 18/8/18 at 02:07 PM |
I think you can get Ali extrusion used for carport type roofs that's a similar profile.
Put 'glazing bar' in an eBay search.
I picked up a couple of ABS sheets that are 5mm thick for when I panel my boot area, it's nice to work with using a jigsaw, I think I got it
from RS Components.
[Edited on 18/8/18 by Andybarbet]
Slimy38
| posted on 18/8/18 at 03:01 PM |
I am expecting to do the same with my car for pockets, what I was going to go for is that odd 'sticky rubber' stuff that holds things
still. This stuff;
https://www.amazon.co.uk/Anti-slip-Resistant-Non-slip-Mobile-Glasses/dp/B0746GM684
But cheaper and in a larger sheet. I figured the fact that it's rubber means that things won't actually rattle, and the sticky idea will
at least slow things down if not stop them moving entirely.
obfripper
| posted on 18/8/18 at 03:32 PM |
lively driving! ).
__¦¦__
through.
Any ideas?
Have a look here for plastic sheet:
http://www.plasticstockist.com/ABS-Sheet.aspx
Dave
| posted on 18/8/18 at 04:15 PM |
Would an aluminium extrusion work? I'm sure I have a length somewhere
ChrisJ15
| posted on 18/8/18 at 04:29 PM |
Thanks for all the suggestions.
Thanks Rusty Nuts but I think almunium would be too much of a PITA to bend to the currved profile of the sill.
I was thinking of using plastic so I could cut wedges out to allow if to follow the curve and use self adhesive velcro so I could move the partitions.
