the_big_1
| posted on 16/6/20 at 03:47 PM |
Handbrake And Gearstick Gaiters
Hi Guys,
What have you used and how fixed, your handbrake and gearstick gaiters.
I have the Sierra handbrake and Type 9 gear stick so looking for options.
Cheers!
Deckman001
| posted on 16/6/20 at 04:35 PM |
I bought mine from Carbuilder solutions, a very good service by them and still open for deliveries. They've a good set of options for the
gaiters, but not many options for the surround frames.
jason
SteveWalker
| posted on 16/6/20 at 04:41 PM |
Just standard off-the-shelf leather effect gaiters and chrome trim rings. The gaiters glued to the underside of the rings and the rings screwed to the
tunnel top.
Something a bit like Gear Gaiters, but a lot cheaper and more variety if you look around.
| posted on 16/6/20 at 04:50 PM |
Made my own gaiters and trim rings
neilp1
| posted on 16/6/20 at 04:51 PM |
I cut my surrounds out of 6mm ali and painted them black as didn't want chrome surrounds. Fitted then with countersunk stet screws into rivnuts.
the_big_1
| posted on 16/6/20 at 05:10 PM |
Hi guys,
Its the handbrake that appears the hardest. No surround to fix the gaiter too??
| posted on 16/6/20 at 06:27 PM |
Make one!
neilp1
| posted on 16/6/20 at 06:47 PM |
one of these any good?
https://www.ebay.co.uk/itm/KIT-CAR-SPECIAL-BUILD-PROJECT-MANUAL-GEAR-LEVER-RUBBER-GAITER-fits-75mm-hole-/373038880542?hash=item56dad9971e
the_big_1
| posted on 16/6/20 at 06:50 PM |
Looking for something matching, the hand brake seems to be the hard one to get
voucht
| posted on 16/6/20 at 07:26 PM |
I bought my gaiters and surroundings from ebay, seller is
c-t-sspares and it seems like he he still selling them (it was in July 2014 for me!)
I punched some holes in the gaiters for the screws, glued the gaiters to the surroundings with Sikaflex, insert rivnuts in the alloy panel and screwed
the surrounding with some head stainless steel allen screws.
Here is the post from my blog about that :
https://vouchtroadster.blogspot.com/2014/12/soufflets-de-le
vier-de-vitesse-et-de.html
Hope that will help
https://caferacer-kawa-gpz-zx550.blogspot.com/
| posted on 17/6/20 at 11:38 AM |
Admittedly they're not matching, but I re-used the gear lever gaitor from my donor Sierra and bought a handbrake gaitor from Ebay for my MK
Indy. The gear leaver gaitor I simply trapped in the top panel cut out using one of the bellow sections. IIRC the handbrake gaitor wasn't
actually fixed to the top panel, but was long enough to stay put. Both worked fine for me and IMHO looked fine as well. Gear lever gaitor was free
and the hand brake one I wouldn't have spent much money on.
Irony
| posted on 18/6/20 at 09:27 PM |
Made both my gaitors and surrounds. Pretty simple to cut the surrounds from 4mm Aluminium sheet and then countersink allen headed stainless bolts.
The gaitors I stitched myself with zero prior experience. Lots of people comment with wonder in their eyes at the gaitors actually. They can't
believe I made them. I built a fricking car!! Trimming a cone out of material stitching it together and turning it insides out was childsplay.
