Author: Subject: bike clocks on car engined car!!
COREdevelopments
posted on 25/2/06 at 06:56 PM Reply With Quote
hi need an answer has anyone used motorbike clocks on a car engined car!? i want to use either r1 or zxr clocks etc. is there anyone out there that can help me please.
thanks Rob
Wadders
posted on 25/2/06 at 07:37 PM Reply With Quote
I don't know if anyones done it, but i cant think of any reason why it shouldn't be possible, certainly the speedo should be no more of a problem than a bec, and all the idiot lights should be straightforward enough, the tacho might require slightly more inegenuity tho.
thanks Rob
MikeR
posted on 26/2/06 at 01:06 AM Reply With Quote
If you get a bike with 12,000 + rpm then as long as you can easily 'lose' 50% of the spark pulses the rev counter shouldn't be an issue, just needs a new face putting on it.
(which is probably really hard!)
DIY Si
posted on 26/2/06 at 11:11 AM Reply With Quote
The rev counter shouldn't be a prob, it just won't go past half way(ish) up the scale. Not sure it would be worth the hassle. A (possibly) not so locost solution is to talk to Smiths Gauges. They can do you a rev counter with a one off back ground. And MikeR you need to get some sleep dude.
MikeR
posted on 26/2/06 at 11:47 AM Reply With Quote
naaah, i'd spent the day sleeping on a sofa ill, from 8pm to 1am sleeping in my bed, after i'd posted that message, powered off the pc and got a drink slept till 11am.........
i don't need sleep, i need to find the git who poisioned me and a friend on friday night!
posted on 26/2/06 at 12:26 PM Reply With Quote
seems to be a common problem down in nuneaton!
MikeR
posted on 26/2/06 at 12:36 PM Reply With Quote
But i was out in Coventry.
Has to be either bad beer or something not cleaned. Three of us went out. One got hammered and the other two merry. The next day hammered girl was fine and she ended up looking after us two. We had the same drinks...... therefore .....
i've drawn my conclusion.
I've not been that ill in a long, long time!
Draw your own conclusions.
