Avoneer
| posted on 30/5/06 at 11:25 PM |
Rubber fuel pipe throughout ???
Someone refresh my memory please.
Can I use rubber fuel hose all the way through the tranny tunnel or does it have to be copper for the majority of it's length?
Pat...
stevebubs
| posted on 31/5/06 at 12:00 AM |
Don't know about SVA, but IMHO, best to use copper as much as possible.
Does this mean you've got your chassis woes sorted then?
muzchap
| posted on 31/5/06 at 12:14 AM |
Agree with Steve - whilst there's no actual rule IIRC - the rubber stuff just flexes far too much (especially with injection)
I know copper is a ball ache - but it's definitely better IMHO...
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
Avoneer
| posted on 31/5/06 at 12:16 AM |
In a fashion.
Will update at the end of the week.
Using copper will mean having to have a connection from the engine to a rubber pipe to the copper pipe, then at the back from the copper pipe to a
rubber pipe to a step down bit and then another rubber pipe and then the fuel pump.
Using rubber throughout would go right from the engine to the step down bit meaning two less connections.
My tunnel is fully enclosed so don't see why not and can't find anything in the manual.
Pat...
indykid
| posted on 31/5/06 at 12:32 AM |
you've got the copper, and olives are only 20p each to give reliable joints. you can than use 5/16" p clips, to save having to get some
bigger ones.
according to the lads on the rhocar forum, rubber pipe leaks petrol vapour, so you car will always smell of petrol too. don't know how much
truth is in it, but copper definitely doesn't.
you know it makes sense!
tom
Danozeman
| posted on 31/5/06 at 05:50 AM |
I was considering doing this too. Maybe better to go 8mm braided right though.
Dan
locostv8
| posted on 31/5/06 at 06:15 AM |
It seems I remember a warning about copper pipe fatiguing and breaking over a period of time. My suggestion would be steel pipe for the tunnel and
braided for the pipe to engine. If you want to save a bit use rubber for the pipe to the tank though I'm using braided.
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
COREdevelopments
| posted on 31/5/06 at 04:30 PM |
im using 200 series braided fuel pipe through out, its already in so hope it will pass. its not the cheap stuff, it cost 90 for 5metres and thats on
the cheap, its in deamon tweeks. very strong stuff too!
| posted on 31/5/06 at 05:39 PM |
either will do; rubber hose is fine; it is not inside the car per se so should not cause fumes leaking; dunno if that is true
there was some discussion not too long ago about copper tubing being bad for injectors - you'll need to search - but given the amount of miles
our cars do, I woldn;t be conerned.
My piping was fitted - rubber hose - but I'd use copper if I were doing it.
You can flare the ends in brake pipe fashion or compression glands so there won't be leaks.
Smartripper
| posted on 31/5/06 at 07:40 PM |
Hello,
I used flex rubber all the way, but in the tunnel i put it in a pvc pipe so its not flexing so much.
Just like others say no extra connections to look after.
Daniel
