dave-69isit
posted on 18/9/06 at 03:32 PM |
triumph gaudges
got a set off triumph clocks i want to use but dont no if i need them recalibrating for use with type 9 box 13 inch wheels any ideas
Bluemoon
| posted on 18/9/06 at 04:13 PM |
I think the speedo is 1000 Rev/Mile. It will be written on the back. If this is the case, and the wheel diameter is the same as the car type 9 came
from it should work o.k, as I think fords speedo's are also 1000 Rev/Mile..
I think there is a company called speedy cables that can help you..
See:
http://www.speedycables.co.uk/
Dan
[Edited on 18/9/06 by Bluemoon]
Rich_T
| posted on 18/9/06 at 05:25 PM |
With regard to the cable, years ago I modified my own. The end that fits to the speedo or gearbox is only crimped to the outer cable so can be removed
and gently recrimped on to another one.
Rich
