RichardK
| posted on 11/11/06 at 07:56 PM |
Clock face clear plastic fronts
Not sure exactly what these are called but I am using the standard sierra clocks and are going to be fixed to my dash back board and will have the
proper board covered in vinyl, but would like to have the speedo viewed through a circle, does anybody know where I can get a slight bowl shaped bit
of clear plastic that I can use to weather proof the speedo, the rev, temp, fuel and lights are rectangle shaped so should be able to get something
for them, it's just the round one I think will be a problem.
If you have any ideas I really would appreciate them.
Rich
Danozeman
| posted on 11/11/06 at 08:16 PM |
Could u not get some perspex and warm it up over a bowl?? It should sag into it. Might need a bit of a push to make it go.
Dan
RichardK
| posted on 11/11/06 at 08:47 PM |
Top idea, not thought of that. Nice one.
Rich
stevec
| posted on 11/11/06 at 09:17 PM |
Some Watch maker/clock shops do these,
May be glass but worth asking.
Steve.
Confused but excited.
| posted on 11/11/06 at 09:54 PM |
You can warm it with a hair dryer. Watch your fingers, to get it to bend it needs to be quite hot. Also be careful when heating. too hot will create
bubbles in the plastic.
Humbug
| posted on 12/11/06 at 10:51 AM |
Might be easier to position the dials slightly back from the face of the dash with appropriate size/shape holes, then mount a flat piece of perspex
behind the dash to cover the holes?
