saigonij
posted on 6/10/07 at 12:23 PM |
seat belt bolts - which nuts?
hi,
I brought a set of Sabelt harnesses ( 4 point ) which were fairly new and unused.
I need to find the correct nylock nuts for the bolts.
I know they could be one of either metric or imperial
Can anyone tell me what they should be. i thought they were 7/16th UNF ( because the tops were ) but the nuts i brought would not screw on....
andyharding
posted on 6/10/07 at 12:27 PM |
7/16 UNF is correct.
Are you a Mac user or a retard?
posted on 6/10/07 at 01:15 PM |
Not necessarily. Some Sabelts are 8mm....
But then thats much smaller than 7/16UNF- the nut would completely slip over them!!
graememk
posted on 6/10/07 at 01:26 PM |
have you got powder coat in the threds ?
saigonij
posted on 6/10/07 at 03:57 PM |
nope.
its the bottom bolts.
the top ones were 7/16 , as i cleaned them out with a tap.
I then brought some 7/16 nyloc bolts for the bottoms, assuming they would be the same thread, but seems like either
1) they are not the same
or
2) the nuts i brought were not actually 7/16 even though i ordered 7/17 nuts...
