jabbahutt
| posted on 5/12/07 at 08:42 AM |
black non counter sink self tappers
Morning all
Anyone any idea where i can get some of the above. I'd like to use them for holding my rear internal panel in place and don't really want
to use silver coloured screws as it'll look like George Michaels underpants
I've looked around and the ones I found are either counter sunk or wood screws which I believe won't be any good going into metal.
Any ideas of national stockists that may be worth a look?
Cheers all
Nigel
RazMan
| posted on 5/12/07 at 08:55 AM |
eBay is your friend
How do you know what George Michael's underpants look like anyway?
[Edited on 5-12-07 by RazMan]
Raz
iank
| posted on 5/12/07 at 09:37 AM |
Do yourself a favour and use rivnuts and proper fasteners if you want it removable, or rivets if you don't.
<soapbox> Self tappers are an abomination designed to enable unskilled workers to fix things together as fast as possible (IMHO).
</soapbox>
Anonymous
jabbahutt
| posted on 5/12/07 at 10:01 AM |
thanks for that
As per the above post then anyone know where I can get button head set screws in black
Razman please believe me it was just an analogy, honest
RazMan
| posted on 5/12/07 at 10:06 AM |
Would you believe
eBay again!
Raz
iank
| posted on 5/12/07 at 10:17 AM |
Or the locost option a can of old engine oil and a blowtorch.
http://www.locostbuilders.co.uk/viewthread.php?tid=76424
Anonymous
| posted on 5/12/07 at 11:07 AM |
I'd second using a method other than self-tappers unless you're only intending to remove that panel a couple of times.... After a couple
of goes you'll inevitably damage the thread thats been cut and they'll fall out and the panel will fall off.... Not nice
daviep
I use a company called BEAL who do black self tappers. No online shop but if you get them to send you a
catalogue you will be very pleased with the prices. They do just about everything a builder will need.
jabbahutt
| posted on 5/12/07 at 12:28 PM |
Another option has just come to mind and wondered if anyone has evr used them.
Just seen the internal panel studs product code 331 on the Woolies web site. They're the type that you used to get on the door panels on older
Fords with the multiple fins on the pin.
Has anyone used them and can they be removed again with a trim tool for instance.
Thanks for all the help.
Nigel
| posted on 5/12/07 at 01:10 PM |
Stick and seal with PU and few rivets (black ones if preferred). IMHO there shouldn't be any need to remove the panel once it's fitted.
| posted on 6/12/07 at 12:09 PM |
should have asked me!!! (ok, I was off sick)
here
shame there is no picture but imagine a posidrive semicircular head but at the base is a flange - a bit like a moulded in washer. If this is too hard
to imagine, I will try to take photo and post.
closest I could find is below but the flange is a bit bigger.
I have used these screws and they will cut into mild steel, not like the sh*te you screwfix sell in their self-tapper pack.
