chris-p-duck
| posted on 3/8/08 at 09:08 AM |
digital dashes
Has anyone fitted or know anything about either of these digital dashes - the Vapour or the Acewell ACE-3150. Are either any good? I think they are
both SVA ok but would appreciate any advice on either inc any fitting issues etc.
I want to be confident I can get it fitted and working before shelling out the dosh!
kevmcdo
| posted on 3/8/08 at 10:10 AM |
I have a vapor unit fitted with the additional dash suround for the warning lights and it works a treat.
Its compact in size so can be fitted behind the steering wheel and it still remains clearly visable.
hector
| posted on 3/8/08 at 11:18 AM |
I have the acewell 3150 and it is fine for SVA, backlit for nighttime and clearly visisble in daylight, very good VFM for £80 i thought!
cheers colin
COREdevelopments
| posted on 3/8/08 at 11:26 AM |
i have used a koso rx1n and passed sva once speedo was setup correctly, only added a brake warning and battery lamp.
rob
chris-p-duck
| posted on 3/8/08 at 11:53 AM |
Cheers guys. How easy are they to wire in and set up? I have a mental block about setting up the speedo part of it. Is it straight forward? Where
do you attach the sensors etc?
tcr
| posted on 6/8/08 at 06:44 PM |
we used the trailtech vapor and mounted the magnet to the prop and the censor on a bracket in the tunnel ok upto 20mph then went off. trailtech sed it
was cos the magnet was spinning to fast so we mounted the mag on back of a wheelstud and the censor through the backplate now it works fine.
the easiest way we found to calibrate it was to have somone follow in a tintop then alter the tyre dimentions upwards in 50mm steps untill it was set
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
chris-p-duck
| posted on 10/8/08 at 08:08 AM |
So not beyond the wit of man then? I guess calibrating any speedo is going to be much the same?
How about the rest of the functionality? Is the speedo the only troublesome bit?
tcr
| posted on 10/8/08 at 06:35 PM |
the water temp sender cable is quite short so we had to run a longer water hose along the bulkhead apart from that it was simple plug and play
,there's a vid of ours in the dash pics section page 8
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
chris-p-duck
| posted on 10/8/08 at 07:27 PM |
Thanks for pointing me at that video. I was a bit concerned by how small it is but having seen the vid I am happy again. It is really quite bright
and clear isn't it?!!!
My mind is almost made up now.............
Cheers - thanks for your help folks......
