eccsmk
posted on 3/5/09 at 09:49 PM |
making a gear lever
whats the best way ??
use a suspension bush and bracket with a tube welded to it,
a tube with a threaded bar welded to it and a pair of rose joints fixed to the threaded bar and then bolted to the tunnel
options and i deas please folks (pictures would be wonderful)
thanking you in advance
Ninehigh
posted on 3/5/09 at 10:49 PM |
I reckon as long as it doesn't look sh!te and it doesn't fall off in your hand do either way
eccsmk
posted on 3/5/09 at 10:56 PM |
thankyou
wanted section here i come
A1
posted on 4/5/09 at 01:16 AM |
the one i have is basically some tube welded to a suspension bush with a wee bracket off the bottom. i dont think i have any pics...
lsdweb
posted on 4/5/09 at 09:48 AM |
Photo of mine here
eccsmk
posted on 4/5/09 at 10:26 AM |
wonderful thank you peeps
matt.c
posted on 4/5/09 at 12:01 PM |
Go paddleshift! Im a touring car style gearchanger lover but wow the paddleshift is fantastic! I would never go back now!
eccsmk
posted on 4/5/09 at 02:14 PM |
we have just looked at putting a lever near the steering wheel.......
any picture of your set up please
YQUSTA
posted on 4/5/09 at 04:14 PM |
you could use cables.
you could also run both a shifter and paddles at the same time.
my paddles use cables but the shifter is rod. both run fine.
http://locostbuilders.co.uk/upload/dash11.jpg
eccsmk
posted on 4/5/09 at 04:31 PM |
funnily ive just spoken to a friend about that he is going to try and getme a cable sorted out and im going to get some 3mm alu to make some paddles
thanking you
YQUSTA
posted on 4/5/09 at 08:05 PM |
My cable is from a boat control. M5 ends of cable.
my paddles are made from 6mm.
eccsmk
posted on 4/5/09 at 09:01 PM |
spot on ive just finished fitting a new column bearing and repairing my bodged gear lever.
just the clutch to sort and then the paddles
