macspeedy
posted on 4/4/04 at 07:52 PM |
Cobra seven seat ques
I'm wondering how other people have mounted the cobra seven seats in there mk's mat clements look like they are raised are they on runners
or spacers at the moment they sit too low in my car to line up? thinking it may pay to get runners?
Mk-Ninja
posted on 4/4/04 at 08:04 PM |
I was advised to bolt them straight to the floor (cross bars) untill you have done the SVA bit, as with runners on it raises the seat so it is touch
and go on seat belt compliance.
HTH Gordon
I'm sure I've got one, just don't know where I've put it
alister667
posted on 4/4/04 at 08:50 PM |
I bolted mine directly onto the floor - onto the flat metal cross pieces. There shouldn't be too many folks apart from me driving the car
anyhow, and it's a comfortable set-up. I'm 5'11" so I'm fairly average in height.
I was told that if I was going for runners to pay attention that they didn't raise the seat to high off the floor. Apparently it can make you
feel like you could fall out of the car!
http://members.lycos.co.uk/alister667/
zetec
posted on 4/4/04 at 09:05 PM |
The problem of seat belt mountings is not a problem if the seat has harness holes and you use 4 point fixings as these are the points that the seat
belt mountings are measured from. This was a thread run just over a year ago I think.
greggors84
posted on 5/4/04 at 12:38 AM |
I am having trouble mounting my passenger seat without runners. The bolts arnt very long and there is quite alot of material to squash down before the
bolt can be screwed in. This makes it really hard to try and fit especially when the holes arnt lined up very well. Think i will get slighly longer
bolts and thick washers to make it easier.
My drivers seat is on runners and feels a bit high but the cobra sevens are have nice side bolsters so keep you nice and snug in the seat!
Chris
The Magnificent 7!
alister667
posted on 5/4/04 at 05:51 PM |
I used longer bolts and big washers into the captive bolts on the seats. This allowed me to use a ratchet to tighten them up instead of an allen key
and use a longer bolt, as you say, - seems a good job. I've also used two of the bolts on the passenger side to hold a bracket for the exhaust.
Seems to be holding up OK.
Fifer
posted on 7/4/04 at 02:37 PM |
I mounted mine on a set of runners I bought at Stafford. cant remember the supplier, but they were in the smaller hall on left as you went in,
selling seats / wheels etc ?
These were about 30 quid the pair and only raise the seat about 25 mm from the floor, (even on a rubber strip as I wanted to keep any moisture that
may (will in Scotland) gather and cause rust on runners).
As stated above, raising the seats does not effect SVA, its the mounting height relative to the seat pad that it is measured from. if you have belt
holes in the seat as I do, the Cobra 7 seat just makes the height rules if your belts pass through the upper most part of the holes then on to the
mounts above this. I asked Cobra about this and they confirmed this is the case and offered assistance with SVA man if he failed it. They did say
that they have had one or two issues here but also confirmed that they sell hundereds of these seats and with only a few exceptions have had no issues
