eznfrank
posted on 20/3/10 at 10:08 AM |
How best to mount my clocks?
Doing more bits on the dash today, going to mount the clocks but I'm not sure how to do it. What I want to do is sikaflex the clocks to the back
of the surround I have and then just bolt that through the dash.
The clocks are not particularly heavy but I'm not sure if they will stay stuck to the surround with just sikaflex? I think the fibreglass dash
will be strong enough.
This is the surround (out of MK's Midi)
[Edited on 20/3/10 by eznfrank]
ReMan
posted on 20/3/10 at 10:10 AM |
Is that a billet ally surround that you've made?
eznfrank
posted on 20/3/10 at 10:14 AM |
No, Martin Keenan made it, I saw it on a picture of his MK Midi in March kitcar mag so I rang him up and asked him to make me one. Would have been too
expensive as took a long time to make but he was changing his clocks so he sold me this one. All nicely radiused for the IVA, I've modified it
slightly by taking the lenses of the clocks and gluing them to the back of the surround and then shielding the bulbs, as it was previously you
couldn;t see the indicator, neutral light etc very well. Very pleased with it
ReMan
posted on 20/3/10 at 10:18 AM |
Could you glue/bond some bolt heads to the back it then fix the clocks to it with plates and nuts?
turbodisplay
posted on 20/3/10 at 03:24 PM |
Nice looking dash that.
Pu adheasive is very strong, it is slightly flexible, when first sets, then goes quite hard.
The strength of pu is rated at a few N per mm2. A 1 cm by one cm square will hold 10 - 20 KG!
Darren
Moorron
posted on 20/3/10 at 06:28 PM |
Hi mate looks really nice, if its thick couldnt you drill and tap the rear of it and then bolt it up from the inside?
ps what size is the ZX12 rev counter 80 or 100mm??
cheers
Sorry about my spelling, im an engineer and only work in numbers.
