givemethebighammer
posted on 7/7/04 at 07:09 PM |
Cardboard type stuff used for door cards and under dash
Anyone know where you can buy the forementioned material. I thinking of making some panels to fit under my dash. Should stop Mr SVA from poking around
under there (probably not)
thanks
theconrodkid
posted on 7/7/04 at 07:30 PM |
hardboard covered with vynil?
who cares who wins
pass the pork pies
Mk-Ninja
posted on 7/7/04 at 08:19 PM |
I paneled under my dash with MDF true changing rooms style. going to rip it all out now its passed
I'm sure I've got one, just don't know where I've put it
posted on 7/7/04 at 08:56 PM |
We used some aluminium sheet... which fell out strange that!
flange nut
posted on 7/7/04 at 08:58 PM |
I remember an item in one of the mags about a material that was 1/4 inch foam sandwiched between thin cardboard. It was light but rigid and easy to
cut. I beleive it was bought from an arts and craft shop. Don't know what it was called.
givemethebighammer
posted on 7/7/04 at 09:14 PM |
ahhh, I think it's called "art board", looks like very thick home made paper if you get my drift. Thanks for the suggestions, but
I'm really looking for something easy to cut and bend but fairly rigid, since it will probably "fall out" after the SVA anyway.
sounds like the art stuff is the way to go. Glue on some vinyl, attach with velcro..
thanks
mangogrooveworkshop
posted on 7/7/04 at 09:27 PM |
thanks
Masionite or hardboard is avail at B&Q
timf
posted on 8/7/04 at 08:23 AM |
quote: Originally posted by Syd Bridge
This has just got me thinking. I'm always on the lookout for new applications of current materials.
You could use that plastic stuff that looks just like corrugated cardboard, like boxes and cartons are made of. I've seen estate agents signs
made using it. It's certainly bendy along the corrugations, but not across.
But where do you get it?
Syd.
Come to think of it, a couple of estate agents sign size pieces would do the job.
google for correx
The Shootist
posted on 8/7/04 at 07:18 PM |
Coraplast
...is the corragated plastic sheet.
Try a sign maker's shop.
