mcg
posted on 2/8/11 at 08:00 AM |
Lower Harness Mounts
My F27 chassis has plates welded into the chassis. (3-4mm thick)
The plan is to drill a suitable hole in the plate, and then either weld a nut to the top, or pass the bolt through and secure with a nut and washer on
the underside.
Which of these routes is best, and are they strong enough, or should I sort the lower harness mounts in another way?
Thanks as always.
Matt
mistergrumpy
posted on 2/8/11 at 10:55 AM |
I've got the same but vertically running as oppose to the horizontal you have and they're on the tunnel. I welded a nut to the plate and
then ran a piece of square section along the long edge of the plate so that it was enclosed on all sides. There was no issue at SVA. I just showed the
examiner photo's and that was it.
mcg
posted on 2/8/11 at 11:25 AM |
cool - so probably ok then running horizontally with a nut welded in the top?
blakep82
posted on 2/8/11 at 11:41 AM |
hmm, i'd have a nut underneath. that way the whole strength of the plate is used, rather than just the weld (which if done right i guess should
be just as strong)
nut underneath will be easier anyway. i'm going to use those FIA spreader plates under mine, even though i've already got 5mm steel strip
welded in
________________________
pewe
posted on 2/8/11 at 11:53 AM |
Mine are mounted on the inner edge of the horizontal outer rail and the angled, rising outer rail - effectively the same on the trans tunnel.
Plate is tapped and I've added a lock-nut between the plate and the outer skin (couldn't weld it as it was already assembled when I bought
it).
For preference I'd say a plain hole through the plate and weld a full size nut on the opposite side to the belt (not on the same side of the
plate as the belt mount) but add a spacer (or top-hat fixing) between belt and mount to allow swivel if the seat adjusts back and forward.
BTW I recently bought a replacement harness from Securon which has pull-up lap straps - sooo much easier to adjust.
HTH.
Cheers, Pewe
