theduck
posted on 5/3/13 at 07:59 PM |
Top hat spacers
I thought I knew what they were used for when fitting seatbelts/harnesses but I have confused myself, so before I complicate matters, what are they
for, and do you have to use them?
posted on 5/3/13 at 08:07 PM |
Use as a spacer to raise the seat belt fitting away from the car to allow room for the fitting to swivel so that the belt isn't strained pulling
at an angle , normally has a wavy washer as an anti rattle device
theduck
posted on 5/3/13 at 08:15 PM |
That's what I thought, so I just acquired some spacers from an mx5 thinking these would be ideal as would take 7/16 thread only to find on both
sets of harnesses i have the hole for the bolts are 7/16 so won't fit over a spacer to allow the movement. One set is an unknown
'cheap' harness and the other trs. The size of the holes suggest needed to use a smaller than 7/16 bolt, which doesn't seem right.
Can only assume manufacturer intended them to be fitted without spacers. Not sure which idea I like less...
