Author: Subject: Fitting luke harnesses
esn163
posted on 30/5/06 at 05:28 PM Reply With Quote
Hi just had our Luke harnesses delivered but not too sure of the correct way of fitting them.
Firstly, does anyone know what thread is needed on the bolt for the Indy welded harness mounts since the bolts supplied seem very tight as if the thread is wrong (is this normal with seatbelt mounts to have a very secure fit? just seem very tight so don't want to force it and end in stripping the threads).
Also, does anyone know what order the bolt goes through each of these?
Thanks in advance
Ed
Indy Build Photos
** Build pages **
Photo Bucket Pics
kev R1
posted on 30/5/06 at 05:57 PM Reply With Quote
not too sure of the thred but some powder coating may have got into the threads thus making it tight, i just kept working the bolt back and forth cleaning the ecess powder coat off with a little wire brush
BKLOCO
posted on 30/5/06 at 06:10 PM Reply With Quote
Thread is generally 7/16 UNF
this is the order to thread them on the bolt:
plain washer
ripped washer
seat belt
stepped bush
fibre
washer
threaded bush
SB
SB
If possible get a tap and run it down the thread.
An alternative is to get an old 7/16 UNF bolt and file a groove across the threads at the botton then lubricate it and run it carefully down each bush. Working it back and forth as you go.
[Edited on 30-5-06 by BKLOCO]
esn163
posted on 30/5/06 at 06:28 PM Reply With Quote
Great, thanks for the fast response
Ed
Indy Build Photos
** Build pages **
Photo Bucket Pics
Paul (Notts)
posted on 30/5/06 at 09:19 PM Reply With Quote
Ed.
Tell Sue I have almost finished marking those papers
Paul
darrenga
posted on 30/5/06 at 10:15 PM Reply With Quote
where did you get your harnesses from and how much if you dont mind me asking
esn163
posted on 30/5/06 at 10:38 PM Reply With Quote
will do paul
Harnesses now fitted and look great
got our harnesses off here. You buy them off him and then he contacts Luke direct for you.
Ed
Indy Build Photos
** Build pages **
Photo Bucket Pics
muzchap
posted on 31/5/06 at 12:21 AM Reply With Quote
Can I confirm these are SVA Compliant - as I heard they were E-marked.
I checked the SVA documentation and it does say if they are fine?
Can anybody confirm this?
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
esn163
posted on 31/5/06 at 08:57 AM Reply With Quote
They are E marked and can be released with one movement so I can't see why not. Think these are the only things that they check at SVA which they may have problems with since otherwise they are like the normal style ones and I can't see why they could fail. Think someone said they had passed at Nottingham with these harnesses anyway.
Ed
[Edited on 31/5/06 by esn163]
Indy Build Photos
** Build pages **
Photo Bucket Pics
