Author: Subject: triumph gaudges
dave-69isit
posted on 18/9/06 at 03:32 PM Reply With Quote
triumph gaudges
got a set off triumph clocks i want to use but dont no if i need them recalibrating for use with type 9 box 13 inch wheels any ideas
Bluemoon
posted on 18/9/06 at 04:13 PM Reply With Quote
I think the speedo is 1000 Rev/Mile. It will be written on the back. If this is the case, and the wheel diameter is the same as the car type 9 came from it should work o.k, as I think fords speedo's are also 1000 Rev/Mile..
I think there is a company called speedy cables that can help you..
See:
http://www.speedycables.co.uk/
Dan
[Edited on 18/9/06 by Bluemoon]
Rich_T
posted on 18/9/06 at 05:25 PM Reply With Quote
With regard to the cable, years ago I modified my own. The end that fits to the speedo or gearbox is only crimped to the outer cable so can be removed and gently recrimped on to another one.
Rich
