grazzledazzle
| posted on 12/11/08 at 08:09 PM |
alcantara glue and technique?
Covering a dashboard which curves in one direction with genuine alcantara. Do i glue the alcantara to the face of the dashboard or glue the overlap
behind it or both?
Also has anyone any experience of a glue which won't let go over time or heat?
Thanks.
Howlor
| posted on 12/11/08 at 08:25 PM |
We made up some panels for the V-Dub camper and covered with Alcantara. We used a spray adhesive as recommended by Woolies. We covered the full lot
rather than just the reverse edge. Granted they are not curvy but it has worked well.
Have a look on the Woolies site for the adhesives.
stevebubs
| posted on 12/11/08 at 08:30 PM |
I covered it all over with spray, waited for it to go tacky then stretched the (faux)alcantara over it...and glued the overlap.
Mine was a compound curve, though.
If you've a simple convex dash then it's really up to you...perhaps try just doing the overlap on a sample first? Cut a 1cm strip that
would go the full height of the dash and give it a go...
I'd start by just gluing the edges and seeing if I could deform the material
[Edited on 12/11/08 by stevebubs]
stevebubs
| posted on 12/11/08 at 08:31 PM |
ps got my contact adhesive from martrim...
grazzledazzle
| posted on 13/11/08 at 05:16 PM |
Cheers chaps.
gottabedone
| posted on 14/11/08 at 10:15 AM |
Did a dash with compound curves (some quite tight) I used both spray from Woolies and Evilstink. The evostick was the best as you can put it on both
surfaces and get a chance to move around the Alcantara and work out creases/bubbles before the glue dries. If it goes horribly wrong you can also
pull the Alcantara off for another go if you're quick. The spray glue lifted on my door panels after a year of so but the Evostick will need a
chisel to get it off.
Hope this helps
