Author: Subject: Dashboard
maskell01
posted on 19/11/08 at 07:29 PM Reply With Quote
Dashboard
This maybe a simple answer, but ive been reading about the dashboards,a lot of people mention a dash radius?
what does this mean?
what needs to have a radius?
Mal
posted on 19/11/08 at 07:45 PM Reply With Quote
Dash Radius
The bottom edge of the dash, where your legs might contact, especially in an accident, needs to be a minimum of 19mm.
maskell01
posted on 19/11/08 at 07:54 PM Reply With Quote
Dash Radius
What do you mean by a minium of 19mm?
sorry for being a bit dull on this?
Ben_Copeland
posted on 19/11/08 at 08:01 PM Reply With Quote
19mm radius i believe
Ben
Locost Map on Google Maps
Enter Your Details Here
adithorp
posted on 19/11/08 at 08:12 PM Reply With Quote
It means that the bottom edge of the dash has to be curved and the radius of that curve must be no less than 19mm.
adrian
http://jpsc.org.uk/forum/
roadrunner
posted on 19/11/08 at 08:25 PM Reply With Quote
Roughly the same as a broom handle.
adithorp
posted on 19/11/08 at 08:28 PM Reply With Quote
Not a broom handle unless yours is 38mm across. 19mm radiuus not diameter!
adrian
Mark G
posted on 19/11/08 at 08:53 PM Reply With Quote
You can see the radius on the bottom edge of the dash blank HERE
jabbahutt
posted on 20/11/08 at 07:47 AM Reply With Quote
or 5mm if made from firm rubber or similar material if that makes things easier
RK
posted on 20/11/08 at 01:58 PM Reply With Quote
You can buy GRP SVA dashes for as little as 10 pounds over there if you look around, and as little as 89 pounds for a CF one. Seems to be a good cost/benefit to me!
[Edited on 20/11/08 by RK]
