Author: Subject: Interior Mirror & Aeroscreens
Adam
posted on 3/12/08 at 08:32 AM Reply With Quote
Hi all,
I've just fitted a bubble style aeroscreen onto my indy and i can't see how i'm going to mount the rear view mirror are they a legal requirment? if so what have people fitted.
Adam
nitram38
posted on 3/12/08 at 08:36 AM Reply With Quote
If you can't fit a centre mirror, you must have both wing mirrors.
Think about vans, they don't have rear views if they have a solid wall behind them or stock in them
Adam
posted on 3/12/08 at 08:37 AM Reply With Quote
thats what i thought but on a search it seems most people say it's a legal requirment
Adam
adithorp
posted on 3/12/08 at 08:38 AM Reply With Quote
Yes, you've got to have one...even if you can't see anything through it. If you can't see the required things through it, then you have to have a near side mirror as well.
I believe some have passed with a mirror fitted in positions where you can't see anything through it, just for the test.
edit... It's an oddity of the SVA that you need one. Just the way the manual is writen/interpreted. Like not needing a horn for SVA.
adrian
[Edited on 3/12/08 by adithorp]
http://jpsc.org.uk/forum/
nitram38
posted on 3/12/08 at 08:39 AM Reply With Quote
My F1-2 car only side mirrors no centre. Passed sva.
clairetoo
posted on 3/12/08 at 08:41 AM Reply With Quote
You only have to have one for SVA - something that will be sorted with IVA I think .
Mine `fell off` on the way home from the SVA , and I've had no MOT problem's without it .
Edit - Adie edited while I was typing
[Edited on 3/12/08 by clairetoo]
Its cuz I is blond , innit
Claire xx
Will weld for food......
adithorp
posted on 3/12/08 at 08:43 AM Reply With Quote
That F1-2 was a centre driving position so not the norm. I've seen a few fails listed on here for it.
Agree it's daft though.
adrian
Mr Whippy
posted on 3/12/08 at 08:45 AM Reply With Quote
not an MOT requirement though, could fit a cheap camera?
adithorp
posted on 3/12/08 at 08:54 AM Reply With Quote
Camera won't do as the SVA states "mirror".
Obligatory are interior and offside. Interior must be fitted unless it would provide NO rear vision (hence Nitrams case).
adrian
whitestu
posted on 3/12/08 at 08:58 AM Reply With Quote
Couldn't you fit a mirror to the top of the scuttle? I used a Halford suction one stuck on with Silicon sealant for SVA. Two years later its still there and works really well.
Stu
Mr Whippy
posted on 3/12/08 at 09:04 AM Reply With Quote
adrian
simple then, bolt a sheet of plywood to the roll bar and then you can't anything and won't need a mirror
posted on 3/12/08 at 10:19 AM Reply With Quote
how about something like this?
Adam
posted on 3/12/08 at 12:25 PM Reply With Quote
car is on the road so not needed for the sva. Fitting the aeroscreen now so that i had no problems with the SVA. I guess it might just stay off and see if i get into trouble. Probably keep one in the car and say it fell off if i get pulled
adithorp
posted on 3/12/08 at 02:50 PM Reply With Quote
You only need an offside mirror and one other to be legal on the road and for MOT.
Interior stuff is just a peculiarity of the SVA so ignore all we've said earlier if its already on the road.
adrian
A1
posted on 3/12/08 at 03:44 PM Reply With Quote
just asked the glasgow tester, he said you need one...
