corrado vr6
| posted on 15/12/08 at 10:58 PM |
indicator buttons on steering wheel??
Hi all,
Thinking of using something like this
thinking of using the buttons as indicators but how can i wire it up so that the wires dont get tangled up when steering.
Any suggestions welcome
Greg
YQUSTA
| posted on 15/12/08 at 11:18 PM |
using something like this will help spiral cable
YQUSTA
mistergrumpy
I have that wheel but I'm not using the buttons. I'm still unsure what SVA view is on them. Anyhow can you rig the wires up to contact
ring connections which stay intact when you use a steering boss?
austin man
| posted on 15/12/08 at 11:21 PM |
you will need to consider auto cancelling for the indicators wont you ????that works off the steering column and the indicator stalk
designer
| posted on 16/12/08 at 12:58 AM |
Is auto cancelling a requirement?
mistergrumpy
| posted on 16/12/08 at 01:04 AM |
Nah not as I know.
nitram38
| posted on 16/12/08 at 07:40 AM |
Auto cancelling is not a requirement of sva as long as you can turn them off by some method.
Thanks for the spiral cable link as it is difficult to get spiral cable in the sizes needed I need one for my veypor dash which is going on my
steering wheel.
A more expensive way of doing the connections is to buy an SPA quick release boss (with connections), but don't expect much change out of £250
Linky
[Edited on 16/12/2008 by nitram38]
Bluemoon
| posted on 16/12/08 at 09:52 AM |
Think about what happened if you need a more than half/one turn on the wheel, you'll not press the correct button??
Dan
designer
| posted on 16/12/08 at 10:01 AM |
Spiral cable should be wrapped around the steering column at least once.
DarrenW
| posted on 16/12/08 at 12:04 PM |
Id be reserving those buttons for operating of digidash functions etc rather than indicators. As said above, if it was me id press the wrong button
when wheel was anything other than dead ahead. (Maybe solved by colour coding - red for right and colour starting with L for left - or even put an L
or R on them).
Dont need self cancelling for SVA. I used a on-off-on toggle switch in exemption area no probs. You must have a dash tell tale though.
lsdweb
| posted on 16/12/08 at 01:14 PM |
I had a similar setup on my Fury a few years ago - it worked well once I got used to it. It was also good cos if I wanted the hazards on I just
pressed both buttons!
Go for it!
As Nitram says though, finding multi core cable with a high enough capacity isn't easy (some truck dealers will stock it for their trailer
connections.
Wyn
