CaptainJosh
| posted on 12/1/09 at 05:18 PM |
Mountney Classic Boss
Hi guys
Im after a Mountney Classic Steering Wheel Boss to fit a 1998ish fiesta/ka. ( The steering column of which is in my locost )
Now the column seems to have a tappered hex section on it and I was wondering if anyone had a clue if any other cars had this same setup?
Can't find one any where,
-Josh
dogwood
| posted on 12/1/09 at 05:41 PM |
Hi Josh.
Can't help where to find the boss you are looking for but
for a Fiesta the number is Mountney KK35X
Be carefully because most have Sierra columns which need a Mountney KK32X
They look the same, but are not interchangeable
HTH David
FREE THE ROADSTER ONE…!!
Danozeman
| posted on 12/1/09 at 05:56 PM |
Is your colum colapsible?? If not then u need a colapsible boss.
Dan
tomprescott
| posted on 12/1/09 at 06:42 PM |
I did mine on a sierra which was a tapered hole that went from hex to round at the taper, don't know if it will fit the same, but it fits mine
and the escort mk2 and a few others like scorpio and granada. Double check the size of the wheel though because mine is a classic mountney wheel and
most mountney bosses were too small - astrali boss may be what you need if its an older wheel.
loggyboy
| posted on 12/1/09 at 08:24 PM |
Mk4 escorts (88ish) have a Hex steering column
trextr7monkey
| posted on 13/1/09 at 12:25 AM |
We had a "mystery" hex Mountney boss that came with a steering wheel but our kits use escort splined mounts so it will be in any one of
about 40 boxes, justhad a quiclk look atsome of thelabels on the off chance
if you have had no luck by weekend drop me a line and I'll tryand dig it out and measure it
dogwood
| posted on 13/1/09 at 08:55 AM |
As my first reply.
Be carefull the Sierra and Fiesta both have hex steering shafts,
They look the same and seem to fit,
but are definatly not the same.
I found out the hard way......
£40 up the spout
CaptainJosh
| posted on 13/1/09 at 12:21 PM |
It seems the Escort and Fiesta one are both KK35
trextr7monkey: If you could check if you've got one of these I would be happy to take it off your hands for some moneys
DarrenW
| posted on 14/1/09 at 10:24 AM |
My column is collapsible, however as i used an aftermarket wheel for SVA i also had to use collapsible boss too. Worth bearing in mind. This is one
reason why people use the column and wheel that the donor vehicle was type approved with.
CaptainJosh
| posted on 14/1/09 at 11:37 AM |
I planning on using the standard wheel and switching it later.
But as I'm not going to be road worthy (SVA passable) before IVA comes in, I'm planning on track day'ing it for a while until I can
be completely aware of the differences between SVA and IVA.
I used to have a Mountney wheel on my racing mini and wouldn't have anything else
recogniseman
| posted on 10/3/09 at 07:03 PM |
Got what you need me'thinks
My KK35X steering boss is for sale on Ebay!
http://cgi.ebay.co.uk/Ford-Steering-wheel-Boss-MOMO-MOUNTNEY-etc-No-Reserve_W0QQitemZ300298671528QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?
hash=item300298671528&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318
Item number 300298671528
Place a bid if you want it.
