richwill
| posted on 23/2/09 at 01:11 PM |
Harness holes in seats
having tried to save money by adapting some old bucket seats to fit i now have a problem. I need to put holes in the seat sides to allow the lap belt
to pass through and i am wondering where i can buy some sort of liner for the holes.
I have seen holes lined with plastic on other bucket seats.
Dangle_kt
| posted on 23/2/09 at 01:18 PM |
plastic u trim? try CBS or depending on the size and shape of the holes self gripping pvc trimming might be better from woolies (not woolworths...they
closed down )
EDIT - Just thought on...how deep are these seats? I guess they aren't just grp buckets?
If not then its more complicated than I realised
[Edited on 23/2/09 by Dangle_kt]
| posted on 23/2/09 at 01:20 PM |
are you sure you want to do that?
I looked into this with a pair of intrim odyssey seats. the inserts are available, about £ 40 a pair but was advice it would compromise the strength.
in the end I did not bother.
the intatrim slotted seats are wider in that area presumably stronger too.
Paul TigerB6
| posted on 23/2/09 at 02:52 PM |
Far better to slightly compromise the strength (of what i presume is a fibreglass bucket seat??) than to compromise the strength of your harnesses by
allowing them to chaff on the raw edges. As above, rubber u-trim properly stuck down will protect your harnesses
Daddylonglegs
| posted on 23/2/09 at 04:46 PM |
Back in the days when I was daft enough to own a caravan, I remember buying some 'U'-shaped trim to go around the window openings when I
did a refurb on mine. Not sure whether it was only available in white (which is what I used) but it was around 1 1/2" wide with a lip of around
1/4" -1/2".
HTH
JB
