bassett
| posted on 6/4/09 at 05:34 PM |
Seat belt mounting bracket sva covers
Hi, my Sabelt seat belt brackets failed on coverings. I had foam covering them but was told this wasnt weather proof and didnt have the density of
rubber and hence failed. Are there any rubber/plastic covers i can get? U trim wont work too well as it overlaps the nut cover. Any ideas?
Flamez
| posted on 6/4/09 at 05:41 PM |
You could try the poly nylon bushes used in suspension they slip over them fixing just leaving the bolt head or loop exposed
my build mac1motorsports
MautoK
| posted on 6/4/09 at 06:50 PM |
I fitted titanfast edging, secured with ty-raps (ends tucked inside the belt loops) and Tifosi nut covers on the bolt heads.
This satisfied Mr SVA.
craig1410
| posted on 6/4/09 at 08:35 PM |
I just used plastic edge trim super glued in position with the ends tucked inside the belt loop. I was surprised at how strongly the super glue stuck
plastic to metal - I think it was due to the metal being powder coated.
See here:
http://gallery.me.com/craig.chamberlain#100014/P1010140&bgcolor=black
This passed SVA without a mention.
Craig.
adithorp
| posted on 6/4/09 at 08:50 PM |
That ^^^ is how I did mine. Small U trim and tucked the ends inside the belt loops. Didn't use any glue though, just pushed on.
People have also used covers from tin-top belts collected from the scrap yard.
adrian
http://jpsc.org.uk/forum/
bassett
| posted on 7/4/09 at 05:51 PM |
Cheers guys i thought it had to be a thicker type of u trim for the radiusing but i have some of the thinner stuff like used in you pic so easy/cheap
solution
Adam
